15 years agoAltera transceiver bits swapped
Hi all. I'm working on a simple transceiver loopback test using a stratixIV GX development kit. I instantiated a simple ALTGX function in basic (PMA direct) mode, and i attached the altera lo...
15 years agothis isnt a bug, you need to bitslip the data until it is aligned. generally there is a training sequence that is either spec'ed by the protocol, or is user specific.
