10 years agoAltera support request 11218245 - Reinstate the auk_ddr_hp_controller.vhd core li
Hi
I am getting the following error: Warning: Can't generate programming files for project because design file "C:/Users/RKanjee/Documents/Pleora/iPort NTX/ntx_mini_pt01_pb0mx1_32tg_20205/ntx_mini_ip_offering_pkg/fpga/application/src/auk_ddr_hp_controller.vhd" is encrypted. It does not have license file support that allows generation of programming files. I spoke to Pleora and they said I must ask you to reinstate the auk_ddr_hp_controller.vhd core license. Once I have that license I will be able to generate the SOF file in Quartus 8.1. Thank you so much Kind Regards Ritesh Kanjee1 Reply
You need to make support requests via the mysupport portal on the altera website.
