14 years agoaltera LVDS receiver
I am currently debugging LVDS receiver on my hardware implemented by altera IP: altlvds_tx/rx. I am facing a problem. When incoming data include more than 4 or 5 successive 0, the received data would...
14 years ago --- Quote Start --- Assuming the link is DC coupled, the receiver bit clock may have an unsuitable alignment. I usually determine the timing margins and center the bit clock to the range. What's your bit rate and expectable sampling window? --- Quote End --- Thanks FvM. Honestly I don't now what the samplng window is and don't know if it is really center alignment. I use Cyconle III device which have limited options to choose. I use control characters for data alignment as recommended by Altera. I write a component by VHDL dedicated for data alignment. I simualted the design by modelsim, there is no issue. Could you please tell me how to check samping window/center alignment? Thanks alot Regards
