17 years agoAltera FFT Vs Matlab FFT. Strange Results
Hi, I’m testing some FFT Altera Core using those parameters: 1)Single Streaming or Burst 16K length FFT 2)12-14-16 bits input REAL data (pseudorandom code {-1,1}) 3)same bits for twiddle...
17 years agoI suggest you to use a simpler source signal in order to debug better. Many sources of problems may be hidden here.
Use a single- or multi-tone test signal to compare the results. That should be easier to analyze.
