17 years agoAltera FFT simulation
I'm working with Altera streaming 256 point FFT core. I've discovered the errata on the core (V9) rearding mismatch between the Matlab sims and HDL sims and the limit on the input range. Looki...
17 years agoDear all,
I'm using the FFT IP, ver.9.0 (Stratix III, 128 points, 16 bit of data and twiddle precisions, single output, 1 engine, burst I/O, global clock enable). I don't understand how to use the signal clk_ena or it doesn't work correctly. In detail, the following cases: 1. clk_ena = always 1: it correctly produce spectrums after about 800 hundred cycles; 2. clk_ena = always 0: it correctly doesn't produce spectrums; 3. clk_ena used to slow down the process (in my example clk=100mhz, clk_ena=50mhz): the behavior looks like case n.2. Is this correct? How did you solve this problem? Thanks a lot! ps: the behaviour is the same also with FFT ver 8.0.
