17 years agoAltera Ethernet MAC (MAC Address)
We are using the Altera Triple Speed Ethernet MAC and I have a question about its configuration. What MAC Address I have to configure the core, from where should I obtain a MAC Address and conf...
17 years agoMAC address are allocated in blocks and registration is controlled by the IEEE.
See here http://standards.ieee.org/regauth/oui/forms/ for the application to buy a range of MAC addresses (Not cheap!) If you are just looking for a quick Lab test and are utterly sure that your kit ill not be connected to the WAN then theoretically you will be safe using any MAC address that is not already used on your LAN. Hope this helps
