9 years agoaltera_dma driver for PCIe
Hi everyone, i'm using an Arria V starter kit for PCIe application and i used the reference design posted in altera wiki. The application software reported success in one PC but not in other with dif...
9 years agoHi there! I am having the same issue with timeout being reported for read and write. Have you found a solution for it? This is the output I see. I am using the driver for linux.
** ALTERA AVMM DMA driver **
** version 2.02 **
** 1) start DMA **
** 2) enable/disable read dma **
** 3) enable/disable write dma **
** 4) enable/disable simul dma **
** 5) set num dwords (256 - 2048) **
** 6) set num descriptors (1 - 128) **
** 8) loop dma **
** 10) exit **
Run Read ? 1
Run Write ? 1
Run Simultaneous ? 0
Read Passed ? 0
Write Passed ? 0
Simultaneous Passed ? 0
Read EPLast timeout ? 1
Write EPLast timeout ? 1
Number of Dwords/Desc : 512
Number of Descriptors : 128
Length of transfer : 256 KB
Rootport address offset : 0
Read Time : 1 s and 366248 us
Read Throughput : 0.000179 GB/S
Write Time : 1 s and 361611 us
Write Throughput : 0.000179 GB/S
Simultaneous Time : 1 s and 362982 us
Simultaneous Throughput : 0.000358 GB/S
