16 years agoAltera Development Tools
Hello 1. Can some one explain the differences between free Tools, Evaluation Tools, Licenced Tools ? By free Tools, I mean tools one can get free of charges. Say download from web, d...
16 years ago --- Quote Start --- Hello 1. Can some one explain the differences between free Tools, Evaluation Tools, Licenced Tools ? By free Tools, I mean tools one can get free of charges. Say download from web, develop a small applications, test it on the CPLD / FPGA an use the CPLD / FPGA. 2. I have a small application consisting of - 3, 16 bit counters - 5, 8 bit Latches - Finite State Macine / State Control Machine of 30 - 50 Gates - Glue Logic - arroun 20 Gates A low end FPGA or High end CPLD should b adequate. It it correct ? 3. Altera FPGA / CPLD chips are non volatile. They retain the configuration after the power is rmoved from the board. The configuration n not be loaded every time they are switch on. Similar to ROM BIOS of a PC. Is it corrct ?? 4. Please recomend tools to be used. If possible free tools. Thanks in advance. GKM --- Quote End --- Hi, only one remark to MSchmitt's reply. You can store your design data in a EPROM. The FPGA still loses it programming when you switch the power off, but it will re-configurate automatically at power-up. Kind regards GPK
