16 years agoAltera Compact flash IP Core Performance
Hi, I am designing a data acquisition system with Altera FPGAs. My system contains a Compact Flash IP core and Nios II processor. My problem is I can’t read and write Compact Flash more than 1...
12 years ago --- Quote Start --- Hi, I am designing a data acquisition system with Altera FPGAs. My system contains a Compact Flash IP core and Nios II processor. My problem is I can’t read and write Compact Flash more than 1MBps with FAT32 file system. I clock the Nios processor at 100MHz and target FPGA is Stratix 1s10.could anybody tell me that what the max performance of the Altera CF ip core is? Unfortunately Altera’s documents for this core is too vague and it is not giving you much information. If IP core is capable enough to cope with data more than 1MBps could you tell me how I can achieve higher speeds? I tried my design with different CF from 1GB to 32GB. Thanks in advance Aidan. --- Quote End --- can you send your code to me?i have trying to write this code like you but never have win....thank you
