dicas3d
3 years agoaltera_avalon_new_sdram_controller
I have a project with Dev board max1000 and altera_avalon_new_sdram_controller and in the last version of quartus prime lite give an error that I can't found this module in Qsys. Today I'm writing to ...
- 3 years ago
I picked an Verilog Model from manufacturer. This is the only thing that is provided as IP Core from him. This is a file .vp and .v for
NC-Verilog
And I don't know how use as an Qsys component. The main file is the .vp.
dicas3d
3 years agoI replaced altera_avalon_new_sdram_controller by altera_avalon_onchip_memory2 which has the same pinout. Is this IP Core replacement good (by good, I mean it gives exactly the same result)?
sstrell
3 years agoIt depends on if the design would work the same whether you are using external memory or onchip memory, since you are making that kind of switch.
