11 years agoAltera Avalon MM DMA controller issues in burst mode
I am having issues with the Altera Avalon MM DMA controller when burst mode is enabled. 1. With small transfer lengths works running DMA host ( RC ) DDR -> DDR , but when I increase the trans...
11 years agoI went into altera_avalon_dma_hw.tcl under the sopc_builder_ip directory and edited the maxBurstSize section... adding 2048 4096 8192
I then opened the QSYS project and the new values appeared ... for the Cyclone IV design ... using a larger number broke the fitter unless I reduced the IMEM size. ... for the Arria V design, I was able to select 8192 ( words ) and I will see if a 32k byte transfer is supported. add_parameter maxBurstSize INTEGER set_parameter_property maxBurstSize DEFAULT_VALUE {128} set_parameter_property maxBurstSize DISPLAY_NAME {Maximum burst size (words)} set_parameter_property maxBurstSize ALLOWED_RANGES {1 2 4 8 16 32 64 128 256 512 1024 2048 4096 8192 } set_parameter_property maxBurstSize AFFECTS_GENERATION {1} set_parameter_property maxBurstSize HDL_PARAMETER {0} Does anyone know where I can get the Cyclone IV PCIe performance application and source code to re-generate the published performance figures found in this document https://www.altera.com/en_us/pdfs/literature/an/an456.pdf ? Thanks Bob.
