12 years agoAltdq_dqs2
Hello Everyone, We are using Arria V GX and the IP ALTDQ_DQS2 with dynamic configuration scan chain. Unfortunately, we cannot complete to compile our design as error occurs. Th...
11 years agoHi All,
I was going to post my solution soon but was too busy. So, Yes I was able to solve the issue. The problem was that since i was only using the Dq_dqs2_bidir IP to write data out so i was not using the Read_data_out lines coming to the core from dq_dqs2 IP. So i added the following code to use the read_data lines and the error "RDEN not legally connected or configured" was not occuring anymore. process(core_clk) begin if(rising_edge(core_clk) ) then read_datacore <= read_data_out; end if; end process; Hope it solves your problem too :) Best regards waqas
