17 years agoALT2GXB rx_pll_locked
All, I'm having a bit of a struggle with the ALT2GXB instance. I have included in my ALT2GXB variation the rx_locktorefclk and rx_locktodata input ports. According to the Stratix II GX user m...
16 years agoThis depends entirely on your design. How are you doing reconfiguration now? Do you have a RAM block that you've created that you load the MIF into? If so, you just need to make sure that the ram initialization file for that RAM block is set correctly to point at your most up-to-date MIF.
Jake
