17 years agoALT2GXB rx_pll_locked
All, I'm having a bit of a struggle with the ALT2GXB instance. I have included in my ALT2GXB variation the rx_locktorefclk and rx_locktodata input ports. According to the Stratix II GX user m...
16 years agoThe configuration for you transceiver is automatically created when you compile your project in Quartus. If you want Quartus to give you the "memory initialization file" (MIF) that represents enable the option in Quartus. It will then give you the MIF files during compilation. When I said I updated my MIF file. I meant that I was using an out-of-date MIF file for reconfiguring the transceiver. I had since changed the transceiver settings and needed to use the newer MIF file for reconfiguration.
Jake
