15 years agoALT2GXB Help................
Hi, I am using the ALT2GXB with the Stratix II GX ep2sgx90ff1508c3 board... I configured the GXB using the Mega core from the quartus... When I run the GXB on the hardware the recieved dat...
15 years ago --- Quote Start --- I saw in the document Stratix II GX PCI Express Development Board that is present in the following link www.altera.com/literature/manual/mnl-s (http://www.altera.com/literature/manual/mnl-s)2gx-pci-express-devkit.pdf
in the fpp configuration section(page 24) we have the figure 2–8. which explains the concept for the pcie configuration, in this we have to select config_mode[1:0] as "00" & dipsw+pgm[2:0] for the configuration file page select - 0,1,2.....
in the same pdf under the max ii cpld configuration controller(page 27) it was told to use the pfl mega function .....
can you please explain me how we can use these in the pcie identification....... --- Quote End --- These references have nothing to do with PCIe identification, they're related to configuring FPGAs. Here's a more detailed reference on that subject, perhaps it is clearer; http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/fpga_configuration.pdf) Cheers, Dave
