17 years agoALT_PLLRECONFIG block busy signal problem
I have implemented ALTPLL_RECONFIG megafunction using an454. I have used 6 mifs, 1 mux, 1 reconfiguration block, 1 reconfigurable pll and a simple state machine. The problem is whenever I run t...
17 years agoyou are right, after initializing read and write parameters, the "busy" signal went low, producing a suitable output.
This point is not declared explicitly in the application note, I hope ALTERA stresses this detail in the next coming version of the application note.
