16 years agoalt_jtagavalon instance index error
I am instantiating two instances of a VHDL component that contains an alt_jtagavalon component. I get the following error. How do I specify different instance indices for the alt_jtagavalon component? I assume there must me a generic (defparam) that I can set, but the component is encrypted so I can't find out what the name of the parameter is. Thanks.
Error: Two instances "hpcii_vhd_example_top:mem_l_exerciser_inst|alt_jtagavalon:jtag_avalon_inst" and "hpcii_vhd_example_top:mem_r_exerciser_inst|alt_jtagavalon:jtag_avalon_inst" of the same debug node with entity name "alt_jtagavalon" have the same instance index 0.1 Reply
After a lot of digging and trial-and-error, I found that the GENERIC is called SLD_NODE_INFO.
This parm is described in "Appendix A. SLD_NODE Discovery and Enumeration" of the Altera "Virtual JTAG (sld_virtual_jtag) Megafunction User Guide". Increment this value for each new instance that you create. I now consider this thread closed.
