18 years agoAlt_asmi
Hi, I have a CyCIII connectet to a serial configuration device. I´m able to configure the CYC III with active serial. Now I want to access the Flash with the ALT_ASMI_Parallel_Interface....
16 years agoWhen I look at the "Device and Pin Options" dialog under "Dual-Purpose pins" the only possibility allowed in the drop down box for the ADS0, nCS0 pins is "As input tri-stated" there is no other choice. For the pin nCEO there are two choices listed "Use as programming pin" and "Use as regular I/O". I will try to see if it works with this setting for ADS0 and nCS0. This is for an EP2C8 with an EPCS4 under Quartus II v9.0.
