18 years agoAlt_asmi
Hi, I have a CyCIII connectet to a serial configuration device. I´m able to configure the CYC III with active serial. Now I want to access the Flash with the ALT_ASMI_Parallel_Interface....
16 years agoThis issue has been fixed in QII 9.0.
But the manual does not document that "Device and Pin Options" -> "Dual-Purpose pins" must all be set to "Use as regular I/O" otherwise the communication to the EPCS is not established. That is omission in the manual is IMHO a bug.
