18 years agoAlt_asmi
Hi, I have a CyCIII connectet to a serial configuration device. I´m able to configure the CYC III with active serial. Now I want to access the Flash with the ALT_ASMI_Parallel_Interface....
18 years ago --- Quote Start --- You can also try to invert the nCS signal by your self and check what happens than :) --- Quote End --- Yea, I'm waiting to hear from MySupport. I'd try inverting but I use the same part for configuration. During configuration the sense of nCS is correct, it's after the FPGA enters user mode it gets hosed.
