18 years agoAlt_asmi
Hi, I have a CyCIII connectet to a serial configuration device. I´m able to configure the CYC III with active serial. Now I want to access the Flash with the ALT_ASMI_Parallel_Interface....
18 years agoif the measurement is OK, the nCS should be inverted. If you are sure that this signal comes directly from the megacore, you should ask the altera technical support with a request on the homepage. This requests are often replied fast. You can also post your solution here.
You can also try to invert the nCS signal by your self and check what happens than :)
