18 years agoAlt_asmi
Hi, I have a CyCIII connectet to a serial configuration device. I´m able to configure the CYC III with active serial. Now I want to access the Flash with the ALT_ASMI_Parallel_Interface....
18 years agoYep, I'm using the correct device n the megafunction (epcs16). It's failing in the actual hardware where as I mentioned earlier the nCS behaves as though it's being inverted. The traces below show the operation during a read through the asmi function. The signals from top to bottom are conf_done, asdi, nCS, data, dclk.
http://patobravo.smugmug.com/photos/218312442-L.jpg
