18 years agoAlt_asmi
Hi, I have a CyCIII connectet to a serial configuration device. I´m able to configure the CYC III with active serial. Now I want to access the Flash with the ALT_ASMI_Parallel_Interface....
18 years agoThe altera megafunction shall work with EPCS devices. I do not have an EPCS device but a ordinary serial flash from STM.
If you have a standard EPCS device this shall work for sure. I only have tested it in simulation and not in hardware. Do you probing in hardware? Ensure that you have selected the right EPCS device in the megacore wizard. In hardware you have to ensure to use the correct pins on the cylone III device.
