15 years agoAlign 2 DVI inputs using VIP
I'm looking into using the VIP suite to do some basic DVI alignment. I have two DVI sources, both at 1080p60 and I'd like to output the two sources aligned on 2 DVI outputs. I'm assuming the VIP suite can do this. My question is regarding the use of Frame Buffers; is there a way to setup the video path such that only one frame buffer is utilized, i.e. one source acts as a master and the other is aligned to it? Any suggestions would be helpful. Thanks, Mike1 Reply
have similar issue and would love to hear any recommendations regarding your problem
