16 years agoAdvice on developing TCP/IP protocol stack on NIOS
Your advice please. I already have two successful designs on different PCBs 1) lwIP/FreeRTOS TCP/IP protocol stack running on ARM microcontroller 2) Another project successfully ported from 80...
14 years agoThank you bmarshall for your informative reply. It is helpful to know that you ran into the very same issues that I have faced. I had to spend a LOT of time on the FPGA-to-PHY interface, which is especially disturbing as it is such a simple interface. As it turned out, I ended up with a very straight-forward solution. The lack of comprehensive documentation made this process far more difficult than it needed to be.
I now have the iniche TCP/IP stack running on a custom board with 512K of SRAM instead of the cumbersome SDRAM. From what you wrote along with the comments and questions of so many others, I can see that I still have a daunting task ahead to bring this design to the product level. I just hope I can get there before the project is abandoned. I am always happy to share my findings with others and would really appreciate hearing from someone who has brought a similar product to market with the Nios II and Qsys. Thanks again for your comments.
