16 years agoAdvice on developing TCP/IP protocol stack on NIOS
Your advice please. I already have two successful designs on different PCBs 1) lwIP/FreeRTOS TCP/IP protocol stack running on ARM microcontroller 2) Another project successfully ported from 80...
14 years agoIn reply to fheineman
I did succeed in getting a TCP/IP protocol stack working on a Cyclone III board. This was in December 2010. I did try porting this work onto another similar board to produce a product but this ran into difficulties and the project was abandoned. So my memory is rather sketchy. I was able to demonstrate - a very simple web server - Modbus protocol The components were NEEK board and the Embedded IP Suite Quartus II 9.1sp1 NIOS II EDS 9.1 SBT µCOS II Altera TSE MAC Altera SGDMA Altera webserver.c Altera http.c Iniche stack v3.1 from Altera The areas that caused the most problems were: Connections between FPGA and the PHY - you have to work this out for yourself and get it right. Removing µCOS II. After getting the stack working with the OS I then converted to using Superloop to avoid the licence fee. This configuration is not documented and there is no simple# define which will remove the OS easily. I never understood completely how Chronos fitted in. I never attempted to use lwIP with NIOS, but I still use it to roll out new products based on an ARM microcontroller.
