16 years agoAdvice about industrial bus for 3,7 Gbps transfers
Dear all, I need to make transfers PC-FPGA based system and need to select a bus for industrial environment. I was considering to use 10 Gpbs Ethernet or 3.0 USB but I am not sure this is the b...
16 years agoThank you very much for the quick answer.
I´m starting to panic as far as I only can spend 6k on IP cores... What do you think about USB 3.0?
