14 years agoaddressing on-chip memory(cyclone IV) from PC via PCIe
Hi freinds, I want to address a on-chip memory in the Cyclone IV FPGA via the HIP PCIe from my computer, so booth the HIP and the Memory are interconnected by the Avalon-MM interface. my ques...
14 years ago --- Quote Start --- This is an in-house application. --- Quote End --- That gives you a little more flexibility for just getting it to work then :) --- Quote Start --- Yes, I've had issues with the BAR size as well. My PXIe board actually has 1GByte of DDR3-SDRAM, and Jungo WinDriver is unable to open my PCIe device for the full 1GBytes (although it did correctly read the BAR settings), so I am configuring the FPGA for only 512 MBytes, which works. (My PC has Win7, 32 bits. I am putting together another PC with Win7 64 bits to try to fix that problem.) --- Quote End --- Another way to deal with this is to have an incoming PCIe translation window. For example, lets say you were restricted to a 128MB BAR0 window, then you could take that window and move it anywhere within the 1GB RAM by setting a base address register in say BAR2. Unfortunately, the Qsys PCIe core does not support this type of dynamic address translation. --- Quote Start --- The Altera PCIe User's Guide indicates that for the Qsys flow (which I am using), 32 bit BARs are only usable for "non-prefetchable memory". I figured that "prefetchable" would be the most efficient option for SDRAM, hence my 64 bit prefetchable BAR selection. --- Quote End --- I don't think it makes any difference to the performance for PCIe (it did for PCI). --- Quote Start --- I suspect that the discrepancy between read and write performance has to do with the controller not pipelining read requests, and that it is waiting for a round-trip read completion before moving on to the next read request. I'm hoping there is some way to pipeline multiple read requests to bring up block read efficiency. --- Quote End --- Have you tried getting the PCIe BFM working? (It only exists in v11.0) Cheers, Dave
