14 years agoaddressing on-chip memory(cyclone IV) from PC via PCIe
Hi freinds, I want to address a on-chip memory in the Cyclone IV FPGA via the HIP PCIe from my computer, so booth the HIP and the Memory are interconnected by the Avalon-MM interface. my ques...
14 years agoHi Dave,
This is an in-house application. Yes, I've had issues with the BAR size as well. My PXIe board actually has 1GByte of DDR3-SDRAM, and Jungo WinDriver is unable to open my PCIe device for the full 1GBytes (although it did correctly read the BAR settings), so I am configuring the FPGA for only 512 MBytes, which works. (My PC has Win7, 32 bits. I am putting together another PC with Win7 64 bits to try to fix that problem.) The Altera PCIe User's Guide indicates that for the Qsys flow (which I am using), 32 bit BARs are only usable for "non-prefetchable memory". I figured that "prefetchable" would be the most efficient option for SDRAM, hence my 64 bit prefetchable BAR selection. As an experiment, I also set up for 32 bits non-prefetchable, 512 MBytes , and was unable to boot the PC at all. I would like to keep this as simple as possible, and avoid using DMA. I suspect that the discrepancy between read and write performance has to do with the controller not pipelining read requests, and that it is waiting for a round-trip read completion before moving on to the next read request. I'm hoping there is some way to pipeline multiple read requests to bring up block read efficiency. AN431 shows a Qsys design with BAR_1_0 access to DDR3, and BAR_2 access to the mSGDMA IP. Failing a simpler solution, I'll play around with mSGDMA ... Regards, Ron
