14 years agoaddressing on-chip memory(cyclone IV) from PC via PCIe
Hi freinds, I want to address a on-chip memory in the Cyclone IV FPGA via the HIP PCIe from my computer, so booth the HIP and the Memory are interconnected by the Avalon-MM interface. my ques...
14 years agoThanks for your insights Matthias.
I have a new Stratix IV GX based PXI Express (PXI Express = PCIe + additional PXI backplane clock/timing strobes) board design, which uses the Altera PCIe Hard IP and DDR3 SDRAM controller. My initial test configuration uses an Avalon MM interface from the PCIe IP to the DDR3 controller. I am set up for 512 MBytes at BAR_1_0, 64 bit pre-fetchable. I am using Jungo WinDriver ALTERA_BlockReadWrite() commands to move data between PXI Express board memory and my host PC. Your explanation of read/write performance is consistent with my results with this set-up: 512 MByte block writes take ~10sec, and block reads take over 3 minutes! I can probably live with the block write performance for now, but have to improve the read performance. Are there any changes I can make short of implementing a DMA solution? Is there a way to make the host PC side pipeline multiple read requests, and not wait for the round trip return of each read before proceeding onto the next read request, for example? Any advice would be greatly appreciated. Best Regards, Ron
