14 years agoaddressing on-chip memory(cyclone IV) from PC via PCIe
Hi freinds, I want to address a on-chip memory in the Cyclone IV FPGA via the HIP PCIe from my computer, so booth the HIP and the Memory are interconnected by the Avalon-MM interface. my ques...
14 years agoThere are some PCIe Switches that contain DMA engines, e.g. from plx technologies (http://www.plxtech.com/products/expresslane/switches). The problem with ready-to-use DMA controllers is that they rarely match the driver’s or device’s specific needs for continuous transfers to the last bit, so a result is typically one interrupt per block transfer instead of one (or even zero) per a long sequence of transfers. And it’s another guy to appear on the PCIe party with already too many of them: CPU/driver, northbridge/memory, switches/flow control, device and application interface. The DMA engine placed into your PCIe endpoint design will always be there in the way designed, but the system DMA engine will only show occasional presence.
And, of course, there is also the option to do inter I/O transfers (peer-to-peer) with even tighter bounding between the devices. I think i2o (http://en.wikipedia.org/wiki/i2o) was then an attempt – as expensive as unsuccessful – to establishing a standard for the device interface which should have resulted in a more abstract CPU↔Device and Device↔Device communication. FWIW, I think both options are beyond the first steps for casamar to go … – Matthias
