14 years agoaddressing on-chip memory(cyclone IV) from PC via PCIe
Hi freinds, I want to address a on-chip memory in the Cyclone IV FPGA via the HIP PCIe from my computer, so booth the HIP and the Memory are interconnected by the Avalon-MM interface. my ques...
14 years agoIf you follow the example design, it’s no big issue. The PC will usually run a sensible operating system which needs a driver for your card. All memory accesses should happen over this driver. And the driver is in charge of doing all the PCI housework like identifying and claiming the device as well as enabling the BAR of the memory in your card. Once the BAR is assigned, the driver is able to access the memory. Linux admins/users can also access the memory BAR from the /sys/bus/pci tree easily without the need for additional drivers.
The only problem is: What performance do you expect from your memory accesses from the PC side? Each memory read access will take between 0.5 and 2 us, depending on the CPU/chipset architecture and speed, and at 100% CPU load you typically reach not more than a couple of MBs per second. Write accesses from the CPU to FPGA memory are just a little bit more efficient, maybe a factor of 2 or 3. And write combining as well as read data prefetching might save you another bit of performance, but this only works with so-called prefetchable memory BARs. If your bandwidth requirements are low, then this is no problem, but at higher rates you will need a DMA structure. With this, not the PC CPU is moving data into or out of your FPGA memory but the FPGA itself will shift blocks of data between main PC memory and FPGA memory. This requires a way more sophisticated architecture of both the FPGA design and the driver architecture, and it typically has a higher latency than the PIO approach you envision. The CDMA example design from Altera will help you towards this goal. – Matthias
