15 years agoAdaptive filter code required
Hi, Does anyone have the VHDL or verilog code for adaptive filter, I am experimenting with my cyclone 2 and would like to implement it on my FPGA, if anyone have the code with them than do...
15 years ago --- Quote Start --- Hi, I was able to make a Simulink model for my adaptive filter....but when I try to generate the vhdl code using HDL coder from the Tool menu, simulink gives me an error message... I have attached my simulink model along with the error message... please help! Also can anyone suggest a way to make this model using DSPbuilder... I have never used DSPbuilder before... --- Quote End --- Hi, I checked you model, works fine. but, you still have some problems in generating the HDL code. I'm using Matlab/Simulink 2010 version, and I performed an quick test on your model, and the result seems to appear linke in these picture:
