15 years agoAbout RapidIO on ArriaII devkit
I have two ArriaII devkits, and the kits communicate with each other by rapidio(1.25Gbps). But I found the rapidio core on both kits are not initialized. The PORT_UNIT register's bit was always asser...
15 years agoIt works now! Because the rate is different from each other. Sometimes the baudrate you set in sopc megacore isn't the same as the rate in "Configure Transceiver ...", we should confirm both of them.
