14 years agoabout mif file question
Hello All advanced:
i created a Block RAM IP from MegaWizard,and addition a XX.mif to RAM for initial value,and gererator XX.pof after compilation xx.mif content as below: WIDTH=16; DEPTH=1; ADDRESS_RADIX=UNS; DATA_RADIX=HEX; CONTENT BEGIN 0 : 1234;END; 1.i programming XX.pof to EPCS,and restart power,then FPGA working Ok, and read XX.mif value is 16'h1234(that is correct) 2.i modify XX.mif value as below,and gererator new XX.pof after re-compilation WIDTH=16; DEPTH=1; ADDRESS_RADIX=UNS; DATA_RADIX=HEX; CONTENT BEGIN 0 : aabb;
END; 3.i programming new XX.pof to EPCS,and restart power,then FPGA working Ok,but read XX.mif value is 16'h1234 rather than 16'aabb so how to solve this problem?
Perhaps Quartus didn't detect the change. Try deleting your /db and /incremental_db directories, recompile, and program the EPCS.
Also I assume you are just testing for now and don't plan on instantiating a single word RAM/ROM (that's a waste of a memory block since you can use a flip flop for that). If you plan one using a single word memory so that you can use the in-system memory editor then you are better off instantiating lpm_constant since you can edit it as well over JTAG. - Altera_Forum
hello Badomen:
very gratitude your answer, i just use a single word for instantiating, actuality, i use memory editor to edit memory content so delet /db that is to say delet all file from /db directory,is correct? - Altera_Forum
That's correct, make sure you delete those files with the Quartus project closed though. You can delete both /db and /incremental_db. By doing this you'll force Quartus to recompile everything.
If you only need to edit one value you don't need an on-chip memory to do this. If you instantiate the megawizard "lpm_constant" you can use the memory editor to modify it on the fly as well and not waste a memory block in the process. I do this from time to time to inject bits into my hardware.
