14 years agoabout mif file question
Hello All advanced: i created a Block RAM IP from MegaWizard,and addition a XX.mif to RAM for initial value,and gererator XX.pof after compilation xx.mif content as below: WIDTH=16; DEPT...
14 years agoPerhaps Quartus didn't detect the change. Try deleting your /db and /incremental_db directories, recompile, and program the EPCS.
Also I assume you are just testing for now and don't plan on instantiating a single word RAM/ROM (that's a waste of a memory block since you can use a flip flop for that). If you plan one using a single word memory so that you can use the in-system memory editor then you are better off instantiating lpm_constant since you can edit it as well over JTAG.
