15 years agoAbout HSMC connectors
Hi I am doing a project on the serial communication using the transceivers present in the Stratix II GX ep2sgx90ff1508c3 For this i am using the HSMC connector slot available on the board for t...
15 years agoThank you Sir:):):):) very much for the quick response
--- Quote Start --- There is a setting under the Assignments menu; Assignments, Device, Device and Pin Options, Unused pins tab. There is a corresponding Tcl command. You can set this option and then generate a Tcl file for the project to determine the parameter for your specific device. Cheers, Dave --- Quote End ---
