15 years agoAbout HSMC connectors
Hi I am doing a project on the serial communication using the transceivers present in the Stratix II GX ep2sgx90ff1508c3 For this i am using the HSMC connector slot available on the board for t...
15 years ago --- Quote Start --- If I insert the HSMC cards(connectors) that is attached here in the HSMC slot the loopback operation should work properly right??? --- Quote End --- Yes, they will implement a loopback of the TX-to-RX signals. --- Quote Start --- Apart from assigning the TXDATA & RXDATA pin locations that are available on the HSMC connectors any other signals should be assigned while doing pin assignment. I only assigned the TXDATA & RXDATA pin locations thats it.... --- Quote End --- Make sure to set the unused pins option to 'as input tri-state' or 'as input with weak-pull-ups enabled' (I think one of these is the default for newer devices) and you'll be fine. Cheers, Dave
