A10 PCIe SRIOV IP not sending completion to Root Port
We are trying to run a simulation with A10 PCIe+SRIOV IP, where Root Port is trying to access a registers behind BAR0 of the IP. There is a write followed by 3 reads from Root Port and the completions for the 3 reads are sent to PF0 of the IP. The IP successfully transmitted 2 Read Completions back to Root Port, but the 3rd completion is stuck in the IP. The Root Port have infinite completion credits, which can be seen on tx_cred* status signals and the IP debug status signals do not indicate any error on the Tx Packets. The simulation fails with completion timeout on the 3rd Read.
Attached is TLP transactions log dump by the IP and completions sent to IP on the AVST-Tx Interface.
We don't understand what is the issue in the IP here.
RamaMohan
- SengKok_L_Intel
Hi RamaMohan,
A quick check with you, could you please double check if this issue only happen in SRIOV variant but not the Avalon ST (without SRIOV) by using the third party BFM?
Regards -SK Lim
