15 years agoA question from China
Good afternoon,everyone I'm from China, and I have a question about LVDS signal ,could somebody help me. I nees change LVDS signal into TTL signal using FPGA. And I don't need deseralizer the ...
15 years agoYou just define the IO_STANDARD for those pins as LVDS and then Quartus will do the rest.
You can do this in either the Pin Planner or the Assignment Editor. You don't need to connect the pin(s) in question to a ALTLVDS block if you don't need the deserialiser or if you want to write your own.
