15 years agoa problems about using posedge
always @ (posedge clk or negedge alarm_in) begin if(cnt_s == set_s && cnt_m == set_m && cnt_h == set_h) alarm_outr <= 1'b1; else if(alarm_in == 1'b0) begin alarm_outr <= 1'b0; ...
15 years agoI think that your idea of :
for : always @ ( in1 or in2) if (in1=1) a =b ; else .... works if you put only the signals in the sensitivity list of the always block. This generates a combinatorial function not triggered on any clock. Further, the lasty line of code that you propose: alarm = ((cnt_s == set_s) && (cnt_m == set_m) && (cnt_h == set_h))? 1'b1:alarm_in; is also good. The warning that you get is because you did not define a wire for the signal alarm. Add the wire declaration and it should be fine. --- Quote Start --- if i have two signal to determine the outcome, i can't put the outcome variable into two always blocks.... so i have to put them into one always block for : always @ ( in1 or in2) if (in1=1) a =b ; else .... i can't change them into always @ (in1) if (...) a=b ; always @ (in2) if(...) a =d so there is always some time i have to put some clock in one block; if i put them into one block,then i meet the problem like the previous one do u have good way to design or handle this situation? i try this way: alarm = ((cnt_s == set_s) && (cnt_m == set_m) && (cnt_h == set_h))? 1'b1:alarm_in; the same logic however it still warning this: Warning (10236): Verilog HDL Implicit Net warning at timeinterrupt.v(116): created implicit net for "alarm" :confused::confused::confused: --- Quote End ---
