12 years agoA problem about FFT Megacore Function
I generated a FFT Megacore Function by Megawizard. The transform length is 2048 and streaming architecture is used. Then I did the function simulation with Modelsim SE 6.5 and this Megacore Func...
12 years ago --- Quote Start --- HI I‘m also FFT Megacore now,and i have some problems , which achitectures are you using? streaming burst or buffered burst ? I'm using burst ,but I can't understand the fifo in the burst architecture --- Quote End --- I tried three operation modes: streaming, buffered burst and burst. The fifo in the FFT Megacore is really obscure. If you are using the burst mode, I recommend you reset the FFT Megacore every time after getting the transform results of last frame and input next frame after the reset signal is deasserted.
