12 years agoA problem about FFT Megacore Function
I generated a FFT Megacore Function by Megawizard. The transform length is 2048 and streaming architecture is used. Then I did the function simulation with Modelsim SE 6.5 and this Megacore Func...
12 years ago --- Quote Start --- same fft input frame must produce same output frame. check you are missing one or so data or inserting a zero in input or cutting it short or duplicating ...etc at the point you change to second frame. Very common. check directly at input to fft and not somewhere ahead. --- Quote End --- Thank you for your quick reply! I have be working on this FFT Megacore beyond 5 days and compared its results with results from MATLAB. All output data flows are correct and the source_error signal is always zero which means, I guess, the FFT Megacore are working normally. Also, I am very sure I used a same block of input data between the sink_sop and sink_eop since I have checked the same data block many times. In fact, Now I tend to believe that it is a bug of the FFT Megacore function.:(
