12 years agoA problem about FFT Megacore Function
I generated a FFT Megacore Function by Megawizard. The transform length is 2048 and streaming architecture is used. Then I did the function simulation with Modelsim SE 6.5 and this Megacore Func...
12 years ago --- Quote Start --- I generated a FFT Megacore Function by Megawizard. The transform length is 2048 and streaming architecture is used. Then I did the function simulation with Modelsim SE 6.5 and this Megacore Function seems working normally: the source_error signal is always zero and other output flows are also correct. But when I checked the detail values of source_real and source_imag, I found a problem: for a same block of input data with length of 2048, when it is transfered to the FFT function as the first input block, a different transform results are gotten compared with the transform results gotten when the same input data block is transfered to the FFT function as the second input block. I am very sure I used a same block of input data, and just the input order was changed, then different transform results were gotten, although the difference is not large. By the way, the transform results are more closer to the results calculated in MATLAB when the input data block is transfered to the FFT function as the first input block. I totally have no idea about this problem, can anyone help me? Thanks!! Tigre --- Quote End --- HI I‘m also FFT Megacore now,and i have some problems , which achitectures are you using? streaming burst or buffered burst ? I'm using burst ,but I can't understand the fifo in the burst architecture
