10 years ago8E1111 PHY tx_clk and rx_clk
Hi, I have a custom board with altera Stratix 4 and 8E1111 PHY. i am trying to initiate the triple speed ethernet IP. a 25MHz crystal is connected with the PHY. i have used the Simple Socket...
10 years agoMy point was that you may have to set the interface you want. Try this link:
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd07082013_58.html Do you have a data sheet for the 88E1111?
