11 years ago88E1111 Marvell PHY Chip Clock
Hi Friends. This post is about Marvell 88E1111. It's close to impossible getting any information from them. On connecting the 25MHz crystal to the XTAL1 and XTAL2, does the chip internally...
11 years agoThanks for your help!
Transmit is working properly. I tried to Use WinDump instead of Wireshark, and it show transmitting UDP packets, and also it said that IP header length mismatch with true length of packet. So I made a mistake at forming IP header. When I correct IP header, Wireshark start capturing UDP packet and UDP receiver at PC start to receive it. Well, thanks again for your advice!
