11 years ago88E1111 Marvell PHY Chip Clock
Hi Friends. This post is about Marvell 88E1111. It's close to impossible getting any information from them. On connecting the 25MHz crystal to the XTAL1 and XTAL2, does the chip internally...
11 years agoDo you see the RX light on the PC? If not, then the Ethernet packet is somehow malformed. Check your transmitted Ethernet and UDP headers, the Ethernet packet checksum and UDP packet data checksum. If you don't see the RX light, I'd suspect the Enet header or checksum. Note that you can't rule out malformed Ethernet packets if you see the light. Some PCs blink the light even if malformed packets are sent. If your packets are malformed, they may be discarded by the OS before being sent to wireshark.
Also, make sure you have Wireshark set the interface to promiscuous mode.
