3G-SDI synthesis error
I am trying to implement 3G-SDI megacore in arria ii gx fpga, i am getting a below error and i am using quartus ii 9.1
Error: Can't find port "rst" in OpenCore Plus entity "sdi_megacore_top". -- OpenCore Plus specification file is invalid any ideas?6 Replies
Have you properly reference the SDI library as a user library?
Jake - Altera_Forum
yes, the tool has automatically included the sdi-library.
any solutions for 3G-SDI synthesis error in quartus 9.1 from altera guru's ??
There was a change in the SDI core between Quartus 9.0 and 9.1. The reset port (rst) was replaced by individual resets for receiver and transmitter (rst_rx and rst_tx). It looks like wherever you are instantiating the SDI core, you are trying to use the old "rst" port, which no longer exists on the 9.1 version of the core.
the SDI instantiation has both rst_rx and rst_tx ports, the error comes when fitter reads the SDI.sdc file...and looks like the .sdc file is not updated with the new SDI core.
this may help:
http://www.altera.com/support/kdb/solutions/rd12162009_635.html looks like you need a license or to wait for SP1.
