ZWang142
6 years ago1/2.5/5/10G Multi-rate Ethernet PHY simulation cannot reach rx_block_lock
The simulation of the example design, provided by the "Low Latency Ethernet 10G MAC" IP, is running fine. However, when simulating my design, the PHY can not acheive rx_block_lock. The waveform sho...
Deshi_Intel
6 years agoHi,
Interesting.
refclk_10g is used in 3 IP. I made below design changes but Modelsim run still failed.
- Can you let me know what's the exact changes that you made ?
Below is the modification steps
- Generate Eth 10G MAC + MultiratePHY with default refclk 644MHz
- Then change refclk from 644MHz to 322MHz for below 3 IP and regenerate the IP
- Multirate PHY, ATX_PLL 10G, core_fPLL
- Modify test bench (tb_top.sv) refclk_10g from 644MHz to 322MHz
- Modify certain IP design files name as the IP has been regenerated (modelsim_files.tcl) in \simulation\ed_sim\setup_scripts\common
dlim
ZWang142
6 years agoForgot to mention: you have to copy the mif files from the newly generated PHY, to the rtl/reconfig folder of the example design...
