15 years ago
11.0 installation on Linux problems
Basically, I wanted to setup Dspbuilder 11.0 and MATLAB 11a on linux64-bit(debian5), so that I can use both standard block set and advanced block set.
After installation, setting some environment variables and adding path/javapath in MATLAB, I could simulate demo models coming with standard block set and advanced block set.
However,
1. 1. when I tried to generate codes from the models from standard block set, I got an error. In the MATLAB command window, it says:
“/local/altera/11.0/quartus/dsp_builder/bin64/libPortManager.so: libdinkum_alt.so: wrong ELF class: ELFCLASS32”;
In the SignalCompiler block log box, it says:
Info: Generating HDL
Info: Analyzing Simulink model
Matlab Error
Java exception occurred:
java.lang.UnsatisfiedLinkError: com.altera.dspbuilder.portmanager.PortManager.checkOut()Z
at com.altera.dspbuilder.portmanager.PortManager.checkOut(Native Method)
at com.altera.dspbuilder.serialisation.ModelSerialiser.<init>(Unknown Source)
Error: Error during compilation: Error: Error analyzing model see log for details.
2.2. When I tried to simulate a demo model and generate code from advanced block set, it asked for a license file on MATLAB path, though I had set LM_LICENSE_FILE pointing to our license server.
Without the license file, it only simulated the model, but didn’t do code generation.
I need to solve both problems. Any solutions or suggestions are appreciated.
